1948 power window switches
Started by Richardonly, October 07, 2011, 08:41:55 AM
Richardonly
Any recomendations regarding rebuilding or replacing the power window switches on a 1948 Fleetwood?
Who seems to have the best price for the kit or the whole switch?
The Bezel # for the switch is 4557793.
Thank you, Richard
1948 Cadillac Fleetwood 60S
1995 Jaguar XJ6
P W Allen CLC# 20193
Richard,
Give Hydro-Electric a call. they may be able to help you. I don't know of any rebuild kits out there. What I do is check e-Bay for used switches and use those parts to rebuild mine. They are fairly easy to repair. There's not a lot to wear out in them, except the springs get weak. But it's almost always the driver side one that gets most of the use and ends up with the weak springs. Another part that can wear and break is the shafts that the switch (s) pivot on. These must be NON CONDUCTIVE. If these are broken they may be tough to find. I have heard of some people have used weed whacker string as a substitute. I tried it once but found it wasn't ridged enough. It did work, but the switches felt mushy when operated. I included a photo of a master switch all disassembled to show all the parts. Notice the two little pivot shafts (the master switch uses two). They look like copper. They are not. I don't know what they are made of, but they are non metalic and easily broken.
Paul
53 Coupe
Twin Turbine
Jeff Maltby 4194
#2
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Hey Jeff,
Thanks for that. I didn't know there were repair kits available. It's funny that they don't include the springs though.
Paul
53 Coupe
Twin Turbine
