Distributor Grease/Lubrication for the flathead 1937-1948 Engines
Started by John Washburn CLC 1067 Sadly deceased., November 11, 2016, 05:02:33 PM
Folks,
Was wondering what type of grease I should put in the "grease cup" on the side of a '40 LaSalle distributor.
Found the answer in the shop manual but was surprised by the answer. See Below:
This is for the grease cup that lubricates the distributor driveshaft bearing.
" Every 1,000 miles Water Pump Grease (G-13) should be applied."
Learn something new every day.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Bobby B
John,
Hi. Don't purchase a whole can just for your distributor. If you want, I can send you a little bit. All you need to do is pack the cup. I live about 20 minutes from the Lubriplate Plant.
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Bobby,
Thanks but since I rebuild the water pumps also I have a good supply.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
