1957, 58, 59 front brake drum . What is this part For ?
Started by Bill Balkie 24172, November 06, 2017, 06:55:48 AM
Bill Balkie 24172
Hello ,
    i purchased a set of good used front brake Drums for my 1957 Cadillac . I am replacing the Bearings inner and outer and also using the new seal provided with the bearing set . i am trying to figure out what this sheet metal cover is for that fits snugly over the outside of the inner hub . it has nothing to do with the grease seal as far as i know . i have added a few pictures .
       Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
