mystery box
Started by chris92026, January 13, 2018, 09:55:55 AM
chris92026
anyone know what this box is for ???
find it on the driver side on the front of the door
thank you
59 Cadillac Sedan Deville
C.Perrin
J. Gomez
Chris,
That would be the Autronic Eye amplifier..!
More details here -> http://forums.cadillaclasalleclub.org/index.php?topic=126591.0
Also a similar manual here -> http://chevy.oldcarmanualproject.com/radios/1959/59cra66.html
Good luck..!
J. Gomez
CLC #23082
I was going to guess something to do with headlights since that was what GUIDE was known for but that seemed like an odd location.   Later years they built the amplifier into the sensor that mounted up behind the grille?
chris92026
thank you, most of the system is gone so I won't use it
thank you for the info
C.Perrin
