73' Eldorado Shifter Cable Bushings PLEASE HELP!!!!
Started by BootsAndCats, April 08, 2019, 01:18:24 PM
BootsAndCats
Hi All! I'm trying to help my grandfather. He is 86 years old, and the original owner of a '73 Cadillac Eldorado convertible. He loves the car, and drives it every day the weather is nice. He has put almost 200,000 miles on it. Now, we have a problem, that I need your help solving.
His mechanics, and myself, cannot locate a replacement shifter cable bushing. Can someone here please help me locate this part? I would be soooo grateful!!!! Thanks!
hornetball
BootsAndCats
Quote from: hornetball on April 08, 2019, 02:03:07 PM
It looks like aftermarket solutions are out there.  Here's one (no personal experience):
https://www.bushingfix.com/cadillac-eldorado-shift-cable-bushing-repair-kit/
They only go back to 1992. I called and she said they might have something compatible. She said to send a picture of the bushing to her. Still looking for other suggestions in case this route doesn't work out.
harvey b
I would try one of the big GM parts guys,that piece is propably the same in a chevelle or camaro?,im sure someone will have it,you will have to do some detective work,or maybe go to a u-pick yard and see if something there wont work.can you get a picture of what you need?,there are lots of people on here with those cars.Good Luck  Harveyb
Harvey Bowness
BootsAndCats
Quote from: harvey b on April 08, 2019, 03:18:21 PM
Who are the "big GM parts guys"? I tried dealerships, and they said their info and systems only go back to the late 70's. They couldn't help me.
Mike Josephic CLC #3877
#5
The shift linkages on the Eldorado's of this vintage
unfortunately used plastic bushings that deteriorated
from age.
When that happens the linkage gets "sloppy" and
sometimes will prevent easily shifting from one gear
to another -- or -- makes you have to "hunt" for the
correct detent.  It usually starts with being unable to
shift into "park".
I'm having thos same issue with my '73 Eldorado and
cannot find replacement bushings anywhere.  My
mechanic told me he would have to make them for me.
If you do find any replacements readily available I'm sure
everyone would like to know.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
harvey b
The big dealers i meant are the aftermarket restoration sellers, one is National Parts depot another was Original Parts Group,you should call and see if you can talk to someone there,they all have websites.Hopefully this part is used on other GMs of the same era?.You may be better off looking for a complete cable as to looking for a part to repair it?. Harvey
Harvey Bowness
BootsAndCats
Quote from: harvey b on April 08, 2019, 04:38:42 PM
Called National Parts Depot and Original Parts Group, neither have the part. I don't know if this bushing was used in another vehicle. Anybody have any other leads I can try?
hornetball
#8
This is the drawing of the 1974 Eldorado transmission linkage from the service manual.  1973 should be the same.  There is no shifter cable.  As for the plastic "grommets," they are no longer available but functional equivalents are easily fabricated.  Some members here have fabricated from universal door hinge bushing kits.  A visit to a decent hardware store with a good selection of bronze or nylon bushing stock would also yield options to tighten things up.  Looks like a fun afternoon project -- but not something for an ordinary automotive repair shop to tackle.  If you're not a DIY, you might need to find more of a restoration shop who can deal with not finding the part at NAPA.
BootsAndCats
Quote from: hornetball on April 08, 2019, 05:02:47 PM
Interesting. It's possible something got lost in translation from the mechanic to my grandfather, to me. My grandfather wrote down "shifter cable bushing" but very possible it was linkage that the mechanic was referring to. Either way, I need the bushing. I am going to take it to a local shop on Friday to get it up in the air and get a picture of the bushing. Still looking for more advice as I am not sure I would be capable of making my own bushing and I doubt the mechanic would go for that.
Kurt Weess
I just replaced the inner grommet on my 78 Eldorado.  The outer grommet was still in good shape as the inner one takes the majority of the load during shifting.  Doorman sells an 8 pc door hinge bushing set, #38374.  The largest bushing in that set is what worked for me.
Kurt Weess
BootsAndCats
Quote from: KWeess on April 08, 2019, 05:45:29 PM
Kurt Weess
Thanks Kurt! Did it require any modification to make it fit?
Kurt Weess
The bushing ID was opened up maybe .010".  The hole in the bracket may be egg shaped depending on how long the grommet was missing.  You'll have to see how the bushing fits.  If it's not too bad it should push in with a slight amount of force.  Upon disassembly when you pull the shaft out of the bracket the outer grommet is designed to retain the shaft so it may take a bit of pulling to get the shaft out.  When you put it back together reuse this grommet so the shaft can snap back into it.  This all assumes that the 73 version is the same as the 78.
Good luck,
Kurt
Flyer
Boots- You might try Oldsmobilenos website. They have a lot of nos parts to fit many GM cars. Good luck. Hugh
#14
In the diagram Horneball posted above the problem bushing / grommet is the one on the diagram between 'relay lever' and 'rod'.   Its the left of the 2 grommets in the 'bracket'.  The right one is plastic and has a ridge in it that locks into the groove in the shaft.
There were 2 styles of that bracket and bushings and they seem to be mixed over the years.  Not sure if there was an early and a late design and many of the early ones maybe got replaced under warranty or what the deal was.  Both styles can have the wear issue and if there ever was individual repair parts they are long out of production for both styles.  I think both styles had a plastic bushing on one side that is also what sort of lock the shaft in from side to side movement.  This never seems to have issues.   The other side is where the wear happens.   One style I don't think had any bushing and the other maybe had a plastic one but it was super thin to start with so it didn't last long.
My recollection was that one of the door bushings fits the shaft fine but you did have to open up the hole a bit in the bracket which needed to be done anyway since it was egg shaped from the wear.   I have a lathe and mill but remember specifically trying to do this with more typical tools to make sure it was reasonable to recommend to others and it was.   I'm pretty sure I used a Dremel type of tool to enlarge and round out the hole to fit the new bushing.  It took some time but wasn't that difficult.  You just marked out where you wanted to remove material and slowly worked at it test fitting along the way till you got it.    The whole crank assembly comes off the car fairly easily so you can get it in a more comfortable position to work on it.
My theory on why this is just an Eldo issue is something about the FWD geometry puts a lot of extra stress on that bushing (or lack of) if you park on even a slight incline.   Even with the wear you can adjust it so P works reliably (which is usually why you notice) but often then the indicator doesn't align which also means park neutral and reverse lights don't align either.  You also can't get to low gear but that usually is the least of the issues.
BootsAndCats
Quote from: Flyer on April 09, 2019, 12:41:51 AM
Thanks, I'm looking into this now. I will report back on it. I am kinda trying to go down all the possible avenues at the same time to try to save time and get the best possible/closest to factory fix.
Quote from: TJ Hopland on April 09, 2019, 09:03:34 AM
Thanks for the detailed reply! I appreciate the advice!
hornetball
#16
ATP has several shift bushing types.  If you click on them, the details have some dimensions.  Wouldn't be surprised if some of these might work with minimal fabrication.
http://atpautomotive.com/auto-transmission?limit=all&subcategory=666
I noticed last night that my inner grommet on the "bracket" is worn out.
BootsAndCats
#17
FOUND SOME! https://www.honestjohn.com/parts/?show_part=175
The guy I spoke with on the phone said it is a generic image on the website. Call him, and tell him the year. You get the whole kit for $60 shipped.
Thanks for that info.  I know the owner (John Faust) and
he's a good guy.  I'll call him and order a set.
2004 Escalade
BootsAndCats
Quote from: Mike Josephic  CLC #3877 on April 09, 2019, 04:17:10 PM
No problem, glad to help! It took a lot of searching to find, but it seems to have paid off. I appreciate everyone's help here, I cross posted on another forum in search of help, and I got wayyyy more help here!
