59 door series 62 / cowl rubber replacement
Started by Kevin Weinstein, December 04, 2008, 06:43:26 PM
Kevin Weinstein
Steele rubber rep says they do not make the 1959  series 62 gutter cowl side drain that goes on body under curved part of front windshield .  Their part says only fits series 75   However they sell same part  for all chevy , pontiac, and olds cars.  Does anyone know it this cowl side drain will also fit a series 62 ?  Is  a 62  windshield and or door same on all full size 59 gm cars?  Thanks for any advice.  I'll try to attach photos of missing rubber.  Kevin
Kevin, I cannot answer directly to your question. Anyway, you are not reading that catalog correctly: the part you are speaking about is for "all pillar models" by Chevy and other makes. At Cadillac, only the 75 Serie has pillars. There must be a difference between hardtop and pillar models; anyway, the windshield are different.
I dont believe all the time what Steele Rubber is writing: they still sell 54-56 trunk weatherstrip for the Brougham model which is totally uncorrect. Even if I wrote years ago that '57 - '58 Broughams have the same trunk weatherstrip as regular model, they did not react. I cannot know, I'm from Switzerland...
Good luck,
Roger
