Oil under dash, driver's side
Started by George D. Mukalian CLC # 10047, May 20, 2012, 10:27:54 AM
I've noticed some oil on the floor mat, driver's side of my 1969 Cadillac Deville.
Does anyone know what it might be?
George D. Mukalian
# 10047
George D. Mukalian
CLC #10047
KD
chech your connection at the oil guage
KD
Ken Dennison
1935 Auburn S/C Cabroilet
1940 Cadillac V16 7 passenger Imperial Sedan (9033)
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
waterzap
#2
Check the seal with the speedo cable going into the transmission. Could be transmission fluid? Can run up the speedo cable as the cable turns. Easy check could be to pull the instrument panel and check for oil back there.
Leesburg, AL
Oil light is tripped by a wire.  Won't be that.
Brian
Mike Josephic CLC #3877
My first thought was brake fluid -- but that's a guess.  However,
I would look at the brake petal and linkage to see is something
isn't seeping into the car.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
