48 49 Trunk Light Switch
Started by Michael Brittan CLC #2750, April 22, 2008, 05:09:22 PM
I refer to the switch on the inside of the trunk lid which is supposed to activate when the trunk lid is opened.  Mine is not working.  I understand that these were mercury switches.  Is there a way to repair these switches once they no longer function?  Any advice would be much appreciated.  Mike
M Brittan
#2750
Jack Mcilwraith
Over time,the arcing when contact is made, carbons the mercury. Once it is totally black,it ceases to work. I have repared these items several times over the years. Between the bulb and the feed wire you will find a small "container". the mercury is in here. the contact can be pried out [carefully] and the mercury either cleaned with a contact spray through the hole where the contact had been. Or you could dump the old mercury and replace with fresh. I have used both methods. I can email a diagram if you wish.
Many thanks Jack.  You experience with these switches is invaluable.  If you could email me the diagram, this would be appreciated.  Where does one buy mercury these days?
M Brittan
#2750
Dave Leger CLC #19256
Hi Mike,
  I have the same issue with my glovebox light (haven't tried the trunk light yet).  Working with mercury worried me, so I did some digging and found the modern equivalent is a tilt switch, which uses a metal ball inside.  I may try to adapt one of these where the mercury cylinder currently is:  http://www.newark.com/tilt .  Just another idea.
Dave
Dave Leger     1947 6207 Club Coupe
