Front Wheel Drive Engine Casting Number???
Started by John Morris #23947, September 02, 2008, 08:44:02 PM
John Morris #23947
My buddy found a motor/tranny set, front wheel drive V-8. He asked me to help id it, and I said that the CLC bunch could likely solve it. The block casting number is 1495200. Would someone who knows, be kind enough to assist? Thank you!!
71 Olds 98 LS, 66 Fairlane 500 XL Convertible, 55 Packard Clipper Super, 58 Edsel Ranger, 72 Cheyenne Super, many 49-60 parts cars, abandoned "House Of Doom" full of 49-60 parts. Huge piles of engine parts, brackets, tin, Hydramatic & Jetaway parts,  thousands of stainless moldings, dozens of perfect sedan doors.
I thought my memory was going but found it on the next page...
http://www.cadillaclasalleclub.org/forum/index.php/topic,102668.0.html
All that number tells you for sure is that its a 70-76 block that left the factory with a 4.300 inch bore.
Depending on the crank and pistons installed weather its a 500 or 472.  A 472 has a 4.060 stroke.  500 has 4.304 stroke.
What makes it FWD is the oil pan/pick up tube, dipstick location, and RH exhaust manifold.
Most likely is a 500 since eldos only came with 500's 70-76 but swap those parts around and a 472 would look and fit the same.
Figuring the year can be harder but the style of pistons, lack of egr, head casting #s can narrow it down.  I guess there was also a vin number but I have never seen one that was readable.
More tidbits, if this motor did not come with a 425(fwd transmission) bolted to it it could have been out of some sort of swap.  The 472/500/425 were and are popular motors to put into hodrods and pickups.  9 times out of 10 the FWD eldo pan is needed because it is the most like a chevy.  Most guys would have gone out and bought a RWD car which would have had a 472 unless it was a 75 or 6 to get the transmission and found out later that they needed the eldo pan.    Measure the bore is the easiest way to tell on a assembled motor.
