vinyl roof eldorado seville 1957
Started by willycadi, April 16, 2013, 01:03:45 PM
willycadi
Hi
I am a Belgium member and I try to find a new vinyl roof for my 1957 seville where can I find or order this?
I want this original can someone help me?
Walter Youshock
Try SMS in Oregon:  http://www.smsautofabrics.com/.  It's not really vinyl.  It's called Vicodec which was a water resistant nylon fabric similar to the material used for convertible tops.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
willycadi
Walter
I have already make contact with sms factory and she don´t have what I need.
Ralph Messina CLC 4937
Walter is correct about the original material being named “Vicodec”. It was a fancy name for convertible top material. The surface texture is sometimes called “pin point” and is the same as most  ’57 convertible tops. The tops were offered in black, white, light blue, light green (a yellow, not blue green) and copper. You’ll likely have to buy the material and have the top sewn. A possible source for the material is:
Sharp Auto upholstery
1527 Lowell St.
Elyria Ohio, USA
440-322-1954.
There was a thin padding under the top approximately 1/16-1/8” thick. The difficult part is that the front and rear window must be removed because the top wraps under the glass mounting rubber. The shop manual shows how it was done at the factory.
HTH,
Ralph
2018 GMC Yukon
