I am in need of a set of Flathead fanbelts without the cogs. They were reproduced by McKvey. I am doing a high point car and am hoping someone has a set sitting on a shelf from a car they sold or .....
I am not particularly concerned with variances in length (most likely can figure out the adjustments - can do machine work or trade pulleys around of .....
I have both a fan and generator belt. They both look like new. I had a generator belt fail after 6000 miles so stopped using these show belts for actual use but they should be fine for show. Email me directly at brad@ipsengarage (dot)com
I'm a little late, but got my belts at NAPA...
ED, DID YOU WRITE DOWN THE PART NUMBERS ?
