1957 mystry gizmo
Started by gary griffin, December 11, 2017, 06:57:18 PM
gary griffin
What is it. Not hooked up and I am not sure where to start with it?
It is in front of the radiator.
If I knew a little more about it I could probably hook it up?
Gary Griffin
cappy102
Looks like part of the A/C system, but I'm guessing, since my '57 is a non-aircon car. I've never seen anything like this, especially in front of the radiator. This car must have been messed with at some point. My 1.5 cents (it's not worth 2).
mb
1957 Cadillac Coupe De Ville
1981 Moto Guzzi V50 Monza
gary griffin
#2
Thanks for the guess Mark.  Since the copper tube is pretty small but not hooked up to anything  I was guessing brake system?? I know the 1957 was a one year brake system  but I know little about it ??
Gary Griffin
Looks like it is a part of the A/C system, as I can see a "Sight Glass" in it.
gene harl
 my guess is some kind of a pre oiler..
  Gene          CLC22406
J. Gomez
I’m with Mark; it sure looks like an A/C aftermarket add-on of some kind and looks like it has a sight-glass. ???
Although the bottom one also seems to be an add-on dehydrator with a pressure switch which the ’57 did not have one. ???
:o
Were you able to trace the line(s) from it and see where they go?
J. Gomez
CLC #23082
gary griffin
#6
Lines were cut off.  I am just starting to sort out 60 years of ???  Brakes very weak. Car runs well and has 80,000 miles believed to be original miles. Seats were still covered with factory clear plastic covers but last owner parked it in the sun and upper upholstery cover is falling apart.  Car is in upholstery shop now and I am planning my attack for when it comes home.
Gary Griffin
chrisntam
It's either an Oscillating Johnson Rod or a Kalupi Valve.
I don't know, but wanted to get my guesses in.
1970 Deville Convertible
Dallas, Texas
I’m with the A/C crowd.  I think the small tube is an oil return line
57 Eldo Seville
It looks like a replacement for the factory A/C unit.
Dave Morris
CLC#28497
1957 Eldorado Seville
2020 CT5-V
Jeff Rosansky CLC #28373
Just to correct you if you don't mind.
A gizmo is something from a Ford product. "Whatchamacallit" is the GM term.
Jeff
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Dan LeBlanc
#11
Gene hit the nail on the head.  That is a Marvel Inverse Oiler - an aftermarket upper cylinder oiling device.  The sight glass is used to set the flow rate to about 2oz of Marvel Mystery Oil per tankful.
This was the better of the units, the other being made by Ampco.
https://www.ebay.com/itm/NOS-Marvel-Mystery-Oil-Inverse-Oiler-Model-TU-2qt-Emerald-Manufacturing-Co/202120201791?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49564%26meid%3Dab83f728ddef4dd0866c0ebce56a456c%26pid%3D100005%26rk%3D1%26rkt%3D1%26sd%3D162118825899&_trksid=p2047675.c100005.m1851
Dan LeBlanc
Dan LeBlanc
If you look at the carburetor base, you'll see where a plate would've been added for the oiler to connect to.  Hopefully it's been blocked off if it's disconnected otherwise you'd have a heck of a vacuum leak.
Dan LeBlanc
gary griffin
#13
 Thank you Gene and Dan. I have been completely baffled as to why my brakes seem to have no power assist.  The tubes are cut off near the gizmo but I have not looked for leaks in the manifold area.  I just need to know if I should hook it back up or remove it and seal the manifold .  Guess I will find some good advice here or flip a coin.
  This forum has amazing bunch of guys and my thanks to all of them that have given me good advice through the years.
  A little detailing and upholstery work and the 57 will be ready for summer.  Put new shocks on the LaSalle as it was bouncing all over the place.  1942 needs a finish up on the upholstery and I will be ready for a break in the spring.
Gary Griffin
Dan LeBlanc
I would just remove the adapter plate from below the carburetor with the fitting (if it hadn't already been done) remove the rest, throw it on eBay and buy a tank of high test with the proceeds.
Dan LeBlanc
gary griffin
#15
Dan, I am pretty sure the plate is still there and is the reason my brakes take so much pedal pressure to work. I was looking in all of the wrong places.
Gary Griffin
cappy102
Honestly, I am amazed by the incredible amount of knowledge and information that is available on this forum. Though I'm not a total fan of the electronic world, imagine how difficult and time consuming it would be to find this information in the 'old world', if you could find it at all! Blows me away.
Many hands make light work...many brains?
I always learn something new on this forum.
gary griffin
Mark,   I think of it as a "Cadillac Brain Trust"   I try to give but so many have so much more knowledge. I started getting responses on this post quite quickly and had a full understanding in a few hours.
Gary Griffin
