Heater hose routing for 41 series 62
Started by steve340, July 01, 2012, 02:34:58 PM
steve340
I am trying to find the correct hookup locations for the heater hoses to an under dash defroster heater to the engine. Where does the shut off valve go also? I think my heater is hooked up wrong since both hoses are going to the water pump, one at the top and one at the bottom.
A. Amman #15293
Here is a diagram for '42,'46, '47 which should be similar.  Another member gave it to me to get mine reconnected.
Anthony #15293
