100,000mile 76 timing set
Started by "Cadillac Kid" Greg Surfas 15364, September 02, 2021, 05:21:54 PM
For those who say that timing sets should be changed without checking them on "older (70's) motors, here is one with 100,000 miles on a 76 Motor.
chrisntam
Yes, but while that nylon gear is oh so quiet, isn't it a ticking time bomb just waiting to bend a *&%#-load of valves?
1970 Deville Convertible
Dallas, Texas
wheikkila
Good Evening
One quick question. How much play is in that chain? You may have gotten lucky that the plastic gear has not broken apart. I can tell you that more have broken then the number of good ones making it to 100.000 miles or more. I can't tell you how many I have replaced and had to remove the pan to clean out all the pieces. It is nice that you are able to replace it before any damage is done. It is time to celebrate.
Thanks Wayne
I had one that looked like that about 10 years ago.  2 months later it shed all that pesky plastic.
Well guys you can stop worrying, the timing set is going to be changed, but the point is twofold. First of all they don't automatically go bad with age OR mileage (I had one go out after 300,000 miles and 40 years and I have had to replace the one on my 66 with only 37,000 miles. The point is check before you jump into timing set replacement, especially with an non interference (large chamber heads) motor.
cadlove
Not quite sure what point you're trying to make here?
Like boasting you tried Russian Roulette with a gun all day and managed not to blow your brains out?
We had a '73 Brougham, eight years old, 41,000 that jumped a tooth. We worked that out and changed it.
You have to remove the front of the motor to see the timing gear, so change them. The nylon teeth wear thin, break off and they need changing. I don't understand what you're trying to tell us Greg? JP
V63
My 70 convertible set went out at 100,000, Pomona California for swap meet. Stopped at a stop light and it 'stalled' never to restart. Had to go to a pep boys there and rent a car yadda yadda
In this day of optical camera devices such as bore scopes an effective inspection can be made through the fuel pump mounting hole or the distributor hole.
Eric DeVirgilis CLC# 8621
Quote from: chrisntam on September 02, 2021, 06:11:28 PM
Only a concern on interference engine which I believe not the case after 1973.
cadlove
Still not sure why you need to see your 40 plus year old nylon toothed timing wheel?
It's a time served service item.
Seeing it cannot tell you when it's going to suddenly shed teeth? JP
You can chose the time, place, and personal to do preventative maintenance,
or let the car chose them for you (and add towing).
When I drive to the coast and back (any coast), I want no car trouble.
Others may only drive to the store.  Bruce Roe
wheikkila
I get your point in a way. we have the tools to check the gear set before we tear the front cover off. And that is good. But it doesn't change the fact the if you have a plastic gear regardless of age or miles it needs to be changed. It is not, if it will brake. But when. The big issue is if you replace it before it brakes you will save a lot of time and money not pulling the oil pan. If it brakes and you don't remove the pan. Then all that ends up in the pickup. Now you just reduced your oil to the engine. I purchased and drove a 98 suburban to 300,000 miles. Never had to do anything to it. Other then general maintenance a water pump and alternator. It still looked and ran great when I gave it to my brother. How drove it for serval years. But I haven't had that luck with any of my other new vehicles. One out of 100,000 or more is not the norm. Like I said. I glad you got to choose the time and place for the replacement.
Thanks Wayne
V63
Quote from: Eric DeVirgilis CLC# 8621 on September 03, 2021, 01:04:32 PM
Were any Cadillac engines interference??? Let's say 1981 or older? My 70 did not bend valves with it's incident.
J. Doogla
Reuse it in one of those big cube engines you talk about.
I sort of doubt that anything short of the Cloyes "hardened gears and chain could hold up to a 300# spring valve train.
