Wanted to buy, for 1980 Fleetwood, Heat Door Modulator asm. This is the unit mounted directly behind the glovebox, that has multiple vacuum lines running to it and has an arm that rotates and opens and closes the chamber door between the heater hot air and A/C cold air. Call 248-709-9471. Tim
Hi Tim, I may be able to get one of these tomorrrow and will let you know if I do. thanks, Jeff in CT
