I am in the process of removing my rear shocks from my Series 63. I have the left rear shock removed from the frame, but I am having trouble disconnecting the shock arm from the connecting link. The nut is off the link.
Is there a special tool I am supposed to use to separate the shock arm from the link?
The links look fairly new so I don't want to risk damaging them.
Any advice is greatly appreciated.
The best thing I have found is a "pickle fork", preferably pneumatic. Harry
Thanks Harry,
It worked like a charm!
Something that works well also is. Hitting it with two hammers on each side at the same time.
Thanks Wayne
An old mechanic showed me how to do this back in the 80's and I've been doing it this way ever since. Place a heavy piece of metal (3 or 4lb ) on one side of the eye holding it firmly it and smack the other side with a fair size hammer and it will pop right out. This prosses works on any tapered seat bolt that you can get at from opposite sides like tie rod ends and ball joints. Tim
