Fuse panel circuit breakers
Started by "Cadillac Kid" Greg Surfas 15364, September 05, 2018, 01:50:07 PM
Anyone have a good source for the circuit breakers that plug into the fuse panel on mid 70s cars?
I believe the plug in kind go by the same size criteria as the fuse size, like ATO, ATC, mini or maxi, etc..   Not sure what's in a 70s but I think that's the first gen for flat fuses, the ones about an inch wide.   Should be a part store item by amp rating.   The usual suspects Balkamp, Buss, etc.
Del city lists them, but not sure if exact OEM.
tripwire
Driving now:
2023 XT4 Luxury
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
