322/346 Flathead Manifold Stud Sealant
Started by LaSalle5019, September 24, 2019, 08:22:34 AM
LaSalle5019
I searched this on the forum and found little.  Most discussions were around head bolt sealant, which seems like Permatex Form-A-Gasket #2 was the most popular choice.  Seems to me like that should work or the Aviation Form-A-Gasket #3 for the manifold studs.  Considering these studs are close to some exhaust ports I was a little concerned about the operating temperature but they do end up in the water jacket at the base. Both products are rated to 400 deg F which seems high enough for that area - just looking for any experience. Thanks.
Scott
Bob Schuman
About ten years ago I used Permatex #2 on the manifold studs of my 1940 LaSalle, still no leaks to my knowledge. It has been with another local friend for the past three years, no complaints from him.
Bob Schuman, CLC#254
2023 XT5
Bobby B
I used nothing but Anti-Seize. Why would you need any sealant on these studs?
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
LaSalle5019
Quote from: Bobby B on September 24, 2019, 07:26:44 PM
        Bobby
Like the head bolts, they terminate into the pressurized water jacket.
Scott
Brad Ipsen CLC #737
Always have used Permatex #2 on these on the ones that go into the water jacket.  From memory not sure if the all go into the water jacket or not.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
