What’s up now?
Started by Carfreak, April 10, 2024, 10:02:28 PM
Carfreak
James Landi
I've had this flick on several times, and, of course, it's unnerving ... fortunately, the message disappears as it apparently did for you. I'm speculating it's simply a computer glitch... perhaps we'll get an official explanation.  James
Lexi
Yikes! I have not seen that message pop up here, yet. Hopefully the tech administrator can provide an explanation. Clay/Lexi
Cadillac Jack 82
I've had that happen to me before.  Try logging out and then back in.  If that doesn't work clear your cache files.
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Stefan Bartelski (CLC Webmaster)
This has probably a connection to our spammer banning process, which bans not only a username and email address but also the IP address that they are using. In this day of mobile data, it does mean that sometimes you can be assigned the IP address that has been used by a spammer in the past. No real easy way around this, other than to turn off your WiFi and then it on again. That should allow you in and remove that message.
Stefan
Stefan Bartelski
webmaster@cadillaclasalleclub.org
470-253-4725
James Landi
#5
"This has probably a connection to our spammer banning process, which bans not only a username and email address but also the IP address that they are using. In this day of mobile data, it does mean that sometimes you can be assigned the IP address that has been used by a spammer in the past. No real easy way around this, other than to turn off your WiFi and then it on again. That should allow you in and remove that message."
I think you're right...some scammer had my passcode (around six months ago) that I used on this site... I changed it months ago, but likely your firewall occasionally links the bad code to me.   Thank you for the explanation.  James
