1962 Coupe DeVille valve cover gasket job - AC compressor bracket removal?
Started by ///Mink, May 06, 2020, 08:53:00 PM
///Mink
Hi all, first post here.  Last year I picked up a 1962 Coupe DeVille in basically stock condition.  I want to replace the valve cover gaskets, which seems like a simple job, doesn't it?  But looking at the right side, I obviously need to remove the AC compressor bracket to get the valve cover off.  The upper end is held on with a nut on the intake manifold, but the lower end is held on by two of the cylinder head bolts.  It seems like a very bad idea to me to remove cylinder head bolts to get the bracket off.  So what's the trick?  Sorry if this has been asked before...
Welcome, Tom.  If you are going to be working on your '62 may I strongly suggest you get a 1962 Cadillac Shop Manual.  Easy to find on eBay and reprints are available, but the originals usually have better quality illustrations.  Best of luck with that car, someone should be able to answer your question soon.
https://www.ebay.com/itm/1962-Cadillac-Service-Shop-Manual-Series-60-62-75-Cars-Commercial-Chassis/312466795211?hash=item48c078eacb:g:9A8AAOSw18BcXaH8
///Mink
Yep, I neglected to mention that I do have the shop manual.  Unfortunately it basically says something along the lines of "remove the compressor bracket"!
Cadman-iac
Tom,
I'm not familiar with the 62 engine and accessories,  but I believe that it may have studs on the top of the head bolts. I've seen this on other GM vehicles, and I can't imagine that they would make the bracket sit under the head bolts.
I could be wrong about that,  but it's worth a look.
Rick
CLC# 32373
///Mink
Wow...that seems like a bad design.  I was always told that the only time you remove a cylinder head bolt is when you're removing the head.  I really appreciate the info.
The joys of owning an older car.  Removing those head bolts won't hurt anything (you won't be running the engine), just make sure they are tightened back to the proper torque when you are finished.
Dan LeBlanc
The other 16 head bolts will keep it clamped down just fine while those two are out.
Dan LeBlanc
Anyone got a photo of what this looks like?  I'm guessing these heads must have quite a skirt around them to have an upper head bolt not under the valve cover?
 :)  Google says, "here, I got plenty!"
///Mink
