1961 headlight switch connectors
Started by Matt 12861, January 03, 2023, 07:21:03 PM
Matt 12861
Does anyone have any idea if they still make these connectors or the manufacturer?  I have a good housing, I need the connectors that crimp on the wires. Thanks,
Matt
Matt Givler #12861
Yes.  They are available.
Here are some pictures of the tools I use.
The Red crimper is for the run-of-the-mill insulated terminals, and the Yellow Kit has different inserts for all applications.   The Blue one is another tool I purchased.   You need the correct tools for these GM-type terminals for really secure joints.
But, in the meantime, search eBay for Item No.  192501982942
And here is a cheap crimping tool  284454816319
These terminals need the correct tool to perform the proper crimp.
J. Gomez
Quote from: Matt 12861 on January 03, 2023, 07:21:03 PMDoes anyone have any idea if they still make these connectors or the manufacturer?  I have a good housing, I need the connectors that crimp on the wires. Thanks,
Matt
Matt,
If you are referring to the wire female ends connectors just do a search for "Delphi 56 type connectors" these are for the smaller ends the larger one would be "Delphi 59 type".
Good luck..!
J. Gomez
CLC #23082
Matt 12861
Perfect! Thanks you guys, Just what I was hoping for.  I might be able to borrow a crimper from work.   I also noticed I posted this in the wrong spot - sorry!
Matt Givler #12861
V63
I default to solder the connectors
