eldo brougham spring conversion
Started by trevor pordage, June 07, 2005, 05:48:29 AM
trevor pordage
hi I have just aquired a 57 eldorado brougham that has been converted to coil springs. the rear control arms are different to what is in the manual . i need to replace the bushes. does any one know if these are compatible with any other cadillac.
also does any one know when cadillac offerd the coil spring replacement option to air spring owners and what parts did it specifically replace
trevor
brisbane
australia
