WTB 66-68 Door Jamb Light Switch
Started by Ralph Messina CLC 4937, September 15, 2014, 12:29:28 PM
Looking for a door jamb switch for the courtesy lights. According to the MPL any three wire switch (2 or 4 door) for 66-68 will work.
Ralph
2018 GMC Yukon
60eldo
   Is this what you need?
Jon. Kluczynski
2018 GMC Yukon
Dave,
Contact John (60Eldo) in the above post. I believe he has two more. They're from a '68.
Ralph
2018 GMC Yukon
George,
I don't anything resembling a door jamb switch.
Ralph
2018 GMC Yukon
70sdv
You have to look at the full catalog to see the switches he is referencing.
Look for part numbers 07599159 (steel tip) or 04002925 (plastic tip). They are $19.
They recommend new terminals with the steel tipped switches. A set 06288128-6 is $8 for six terminals. Hope this helps.
Steve McCarthy
Guys,
Thanks for letting me now where to look. I'm not certain that's the correct switch. There's no mention of being a three wire system. I have located a replacement from a parts car.
Ralph
2018 GMC Yukon
cadillacmike68
1968 used 3 wires, a lot of other years used only 2. I usually don't delve back earlier than 1967 when looking for this type of part, so I'm not sure on 1966.
"Cadillac" Mike
