1960 Rotary Vacuum Valve WTB
Started by Thor, November 16, 2012, 08:26:27 PM
Thor
Hi Gang:
  I am in need of the rotary vacuum valve found in a 1960 A/C dash panel - it's the one on the left with 3 nipples and has a spring on a post to make it track the main control lever cam profile.
The original valve was very sticky, and I broke off the post without realizing that it should have been lubed first (D'oh!)   :o
The valve looks to be made of zinc, and I wonder if the same part was used in other GM brands like Chevy, etc..
Thanks for your help.
Randy Bergum
CLC #26162
Ken Perry
Hi,Im sure I have what you are looking for. Can you send a pic of the broken one? I will look for it. Email cadmanken@netzero.net  Ken Perry
Cadillac Ken
Thor
Hi Ken:
Will do - You are the Shell Answer Man!
Randy Bergum
26162
Jeffrey Burland
Just reading this. Hi Thor, This is Gr. 54.6415 Control valve, # 7274141. It's the same valve used on the other side.
Used for 59-60 AC cars -  all and 61-62 series 75 and CC only . HTH, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
Thor
