Edelbrock 1406 on a 59 Cadillac?
Started by kib, July 14, 2012, 03:05:48 PM
kib
I had so many issues on my carb the Rochester 4 brl, adjusted and adjusted but with no luck so fare. The carb is nt old but rebuilt and expencive enough. Is there any of the members having experience with Edelbrock carb on a 59 model? Gusee ther emust be adaptors in both ends to can use the air cleaner etc?
T.Kibsgaard
Couild be wrong but I beleive Carter AFB/Edelbrock should bolt to the manifold, fuel lines linkage and choke may need some adapting.  Check the bolt pattern and throttle bore spacing and size, Btw I have never had an issue rebuilding the Rochester 4gc carb.
kib
Thanks!
To have the idle adjustet I need 4 turns on both sides to have the engine run near to normal during driving.
I understand it should be only 2 1/4 turn?
Thore
Jeff Wilk
Same here.  This carb is one of the most reliable.  Custom Rebuilt Carbs is an expert shop on these and can mY e offer some advice.   Customrebuiltcarbs.com
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
R Schroeder
Those two screws in the front are air / fuel mixture screws. Not the idle screw. The idle screw is on the driver side. The throttle tab stops up againist it.
The two in front are to be backed out until you get your highest rpm's,from about 2 turns out to start with. Then adjust the one on the side.
I can see why your having problems.
Roy
kib
Roy, when I have aprox 4 turns I got the highest rpm and the turn them back in?
Brg
Thore
R Schroeder
#6
IF the rpm's stopped going up at 4 turns ,then you leave them alone. You may have to check each side ,going back and forth a couple of times, by going in on the screw, and then out to get the highest rpm. Then adjust the engine speed on the side of the carb for idle. Don't touch the front ones again, unless you want to try to fine tune the air/fuel mix once more. Then set idle speed screw on the side again.
kib
thanks for thie information
Brg Thore
R Schroeder
If that quadrajet is adjusted in right it should run very nice. They give you very little problems.
Guys, remember this is not a Quadrajet, also a vacuum  gage is the best way to finalize a good idle setting, sorry if I am a PITA.
R Schroeder
#10
He stated it was a Rochester carb in his first sentence. To me that means Quadrajet. Right ?
I didnt want to get to technical with him. Yes the vacuum is one of the best ways. I use tach,and vacuum.
Wanted to see if he got it any better with what was told to him.
Dave, your not a PITA......................ha
Roy
http://www.carbkitsource.com/carbs/tech/Rochester/Quadrajet-index.html
Bob Hoffmann CLC#96
Dave is correct. A 59 carb is a regular Rochester  4 barrell. The quadrajet came out in 1967 on Cadillacs & had  much larger secondaries.
HTH, Bob
R Schroeder
#12
But they are adjusted the same. Correct ?
As far as the air fuel mixture. All that I ever worked on, are the same as far as setting the air/fuel mixture , for idle.
Roy
Philippe M. Ruel
The 4-turn base setting holds for Quadrajets.
Earlier "4-jet" (4GC) Rochesters require only about 1-1/2 to 2 turns.
1952 60 Special in France.
kib
#14
Hi my, the carburetor is the original 1959 Rochester 4 GC as on the pictures in the manual section 10-35.
This one was re built in 2007 and still not work as I want it to. If I use only 1-1/2 to 2 turns the car just stop. But if I use 3-4 turns it will work in a way.
Brg
Thore
R Schroeder
It is possible you have other issues. Timing, vacuum leaks and the like.
Roy
Bill Caddyshack
I have just put a 1406 Edelbrock on my 59. I replaced a Carter and the fuel line fit exactly. Had to do a little modification and take part of the Carter linkage for the TV, but it works. Also be sure to hook up the electric choke to a key switched power source. I had it hooked to the + side of the coil and it did not work. I am going to hook it to the wiper motor.
Car starts runs very good with the new carb. I did have to get an aftermarket air filter as the Edelbrock throat is quite a bit bigger than the Carter. I am hoping to find an adapter that will allow me to use the stock filter.
Anyone know of such an adapter?
I do have one other question. The front of the 1406 has two small vacuum ports. The one on the passenger side, according to the Edelbrock CD is for "timed vacuum" the port on the driver side is "constant vacuum."
Any idea about which of these ports to hook to the timing advance on the distributor?
Gene Beaird
I wouldn't be too concerned with how many turns it takes to get the car to idle well, just that you _can_ adjust idle quality with those screws.  There are a lot of variables that can determine how many turns it takes to get the car to idle properly, and weather/altitude can be a very big factor.  The condition of the engine can be another.
So start at 2-1/2 turns and see where you end up.  Don't be concerned that you are past 2-1/2 turns as long as you can get a proper idle.
@Bill; will this kit help:
http://www.autozone.com/autozone/accessories/Spectre-Air-cleaner-adapter-and-riser-kit/_/N-256l?itemIdentifier=228335_0_0_
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
curly
@Bill,
I have the same set up on my 59 Fleetwood. I used the timed vacuum at first, but I found the engine ran better with the manifold vacuum port hooked to the distributor.   I also used a relay on my electric choke to minimize the draw on the wiper circuit.
I'd be interested in an air cleaner adaptor as well.  I tried a similar kit to the one Gene linked in the post above, it didn't work. It was a different part number though.
T Lewis
Bill Caddyshack
Outer diameter of throats is about 4 5/8" old Carter/Rochester to 5 1/4" 1406 Edelbrock.
I appreciate the input about the advance and it would make sense not to use the "timed advance" whatever that is, and use the manifold constant vac like it was made for in 1958/59.
