1965 429 intake manifold
Started by danekejt, June 08, 2021, 03:51:57 PM
danekejt
Quote from: scotth3886 on June 10, 2021, 09:59:54 AM
Yep, that's it.  I couldn't remember the name of the company who made and sold these.
ok so i just got off the phone with olson's and i should have a set by mid next week.  will see how these go.  thank you for the info.
thank you all again for all the advice.  very much appreciated.
john
scotth3886
Quote from: danekejt on June 11, 2021, 03:09:52 PM
john
If you don't drive much in cold weather, you should be fine.   It's been seven or eight months since I did mine.  Although I had a bunch of cold start and stay running problems when it got really cold I fixed that by screwing around with the choke and idle mixture a bit.
