linkage connections manual shift 41 60 special
Started by mr41cadillac, February 26, 2014, 07:15:35 AM
mr41cadillac
anyone have close up of the shift linkage and the clutch rod connections to bell housing arm for 41 60 special manual transmission / thanks john
Bill Ingler #7799
John: Please take a look at the pictures below. The clutch pedal is #1. Number 2 is the lever with 3 being the arm of that lever that is connected to what they call a link with the other end of that link connected to the clutch pedal. Number 4 is the engine side arm of the lever which connects the eye of the long threaded bolt, the other end of that bolt is attached to the clutch yoke with nut and washer. Push in on the clutch pedal moves both arms of the lever which in turn moves to engage or disengage the clutch.  Bill
mr41cadillac
the problem im having is on the lock retainer spring. how does the round end of the nut fit in the eye of the lever? I don't want to break it . im guessing the groove on the adjusting nut fits in lock retainer spring? thanks john
mr41cadillac
