1960 Carter Gasket
Started by 60eldo, May 06, 2024, 06:58:25 PM
60eldo
  I was looking at my carb gasket today while still waiting for my engine to be rebuilt. Hope 2 wks more. The thin cardboard gasket on the right was on my car. The 3 others were on a 60 manifold that I had in garage, all 3 were on it. The second from the left is a thick rubber like gasket, and the far left thin metal. Which should I order for my carter.
Jon. Kluczynski
gkhashem
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
Clewisiii
Carter needs the thin metal shim. Then there is the thick phenolic spacer, and two fiber gaskets.
There is an article in the self starter from a year or two ago that talks about this stack up.
60eldo
Engine #06K56705 Also there are 2 groves in the manifold carb sits on top. What are those,,,see pics
Jon. Kluczynski
rwchatham CLC 21892
From the manifold up it should be gasket , thick spacer , gasket , thin metal plate , carburetor.
R. Waligora
Clewisiii
Clewisiii
I did not have a carter, so i do not have the tin shim.
IMG_20230715_103436785.jpgIMG_20230715_103512680.jpgIMG_20200710_182449123.jpgIMG_20230715_103528884.jpgIMG_20230715_103449938.jpgIMG_20230715_103521763.jpg
60eldo
Yes thanks Chewii I did open it, I will read it. Heres one. If I had only the thin cardboard one and I raise the carb 1/4 in or so. Im thinking my TV rod will have to be re adjusted. Also my car ran ok with just that gasket
Jon. Kluczynski
60eldo
 So where can I get these 4 gaskets.
Jon. Kluczynski
Clewisiii
I had a spare tin shim that I did not need from my parts car. I have it away in a previous thread to someone in Chicago. I don't know if he took it just for a spare or if he needed it. Maybe he can reach out if he wants to make it available.
The phenolic spacer I think you need to hunt down an original. I don't know if anyone makes a new one.
My gaskets I bought a felpro set.
Clewisiii
Unfortunately my conversation with whoever I gave my Carter shim to was in the lost era on the forum. I don't know who I sent it to.
Caddyholic
1962 Coupe Deville
gkhashem
1970 GMC C1500
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
60eldo
 Thats crazy thats 200 my money. Maybe I will just put one of the thin gaskets on. Thats how my old engine was and no problems. Unless someone can tell me why I shouldnt.
Jon. Kluczynski
Clewisiii
I have a spare one of these you can have that has a small crack in it. I was going to seal it up with some exhaust sealant, but then my parts car had a good one so I did not. I probably have two spare gaskets you can have as well. Just missing the tin.
60eldo
  I have a tin good shape, Give me a ph# or i can give you mine, we can talk,,your the best
Jon. Kluczynski
Clewisiii
I gently pried open this crack. Then worked high heat sealant on all four sides into the crack. Then clamped the sides closed and cleaned the surfaces. I left a layer on the inside edge that should make a barrier. I will let this dry up then get into the mail hopefully Friday.
60eldo
Jon. Kluczynski
