1976 Cadillac Fleetwood Driver-Side Rear Fender / Quarter needed
Started by Znuh, September 01, 2017, 03:59:40 PM
Znuh
Good afternoon,
I'm about to purchase a very low miles, quite intact 1976 Fleetwood Brougham. The Kicker: the rear fender (Driver's side) was hit by a Town Plow Truck, which pushed a nice vertical crease into the car, just behind the rear door. I've included a picture.
I'm having trouble finding anything for replacement sheetmetal, it's so pushed in that there's no real hope of pulling this out. Does anyone know where I can get a replacement panel, either new or used?
Many thanks,
James F. Smith
Portland, Maine
Any Panel beater worth his salt will be able to get that dent out.
Easier than getting and fitting a replacement.   Plus, less damage to the surrounding area as well.
V63
I have rust free 1/4's available for 74-75-76 fleetwood (i.e.: brougham) $400ea, in Arizona.
All Other parts available too
Znuh
Quote from: The Tassie Devil(le) on September 01, 2017, 07:02:09 PM
Quote from: V63 on September 01, 2017, 07:23:56 PM
Bruce, V63, thank you for your quick replies! I'm going to take a proper look in one hour; with luck Bruce will be correct. If not, V63, could you kindly give me a way to contact you to order the quarter?
Best,
James F. Smith
Portland, Maine
Znuh
Just purchased the car, rust-free with the exception of rust starting on the C pillars, an apparent original 59,000 miles, $1100.
Bruce, I'm going to see about getting those dents pulled out; in person they don't look too bad.
Many thanks,
James F. Smith
Porltland, Maine
