1959 Eldorado Rear Grille Bullets and Top Door and Qtr panel Eldorado trim
Started by fazool, June 14, 2016, 06:04:17 PM
fazool
Hi All,
  I'm looking for 2 rear Grille Bullets and a complete set of Top Door and Top Quarter Panel  Long Trim for a '59 Eldorado Seville, I know a tough one!
  Any help or leads would be greatly appreciated!!
  Thanks for looking and in advance for your time!!
  Sincerely,
  Jon                         914 582 0498    jfortun1@optonline.net
David Greenburg
Jon:
If you can't find the rear bullets, you can cut front bullets down to fit.  Much cheaper and easier to find!
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
fazool
