On the old flatheads there are three pieces of exhaust manifold bolted to each other. Are there supposed to be donuts between the sections of casting? Also, should there be a donut between the manifold and the headpipe? Or do these use flat fiber gaskets (asbestos or substitute)?
There are two flat gaskets for the crossover pipe and a flat gasket for the exhaust pipe/manifold interface. The two exhaust manifolds use a longer strip gasket with several holes. All are fiber or asbestos-type gaskets. They are available from Coopers as a set.
Also available from Terrill Machine. Adv. in HMN.
