'75 Eldorado front seat rocking
Started by benji808, May 06, 2022, 02:59:19 PM
benji808
The driver's seat has about an inch of movement - that is, I can grip the bottom of the seat and freely rock it up and back about an inch with minimal effort. All the power controls work, and the seat seems otherwise stable. I know very little about the chair setup, but do have a GM diagram (attached) that I'm trying to understand. Any ideas on what part(s) may be causing this?
Check the bolts that attach the seat mechanism to the floor (they are under plastic shields) and those that hold the seat itself to the mechanism ((chech these with the seat fully up).
Also, check the bolts that secure the jackscrews to the seat frame and adjusting mechanism.
When I purchased my '72 in 2008, I found that these bolts had come out, and the previous owner had stuck a piece of tin to hold the seat together.
J. Skelly
Also check for floorpan crossmember or floorpan rust where the seat bolts to the floor.
Jim Skelly, CLC #15958
1968 Eldorado
1977 Eldorado Biarritz
1971 Eldorado (RIP)
benji808
Thanks, all! It's at the body shop for bumper fillers right now, but I'll look into these when I get it back.
benji808
Got around to looking at this today. There are 4 "gear nuts" (essentially electric pistons), one at each corner of the seat, that tilt the seat when the seat motor is engaged. One of these in the front was missing a bolt. It looks like someone lost the original bolt and tried to make due with a non-spec bolt, did not get it in tight enough so it slipped out.
Pretty simple job... seat has two bolts or washers at each corner, which I removed so I could get at the bottom of the seat (they are 1/2", I recommend a short socket, a long socket, and an open-end as there are a couple awkward positions). Once these were removed I tilted the seat back and could easily access the gear nut bolts, which thread through the channel into the gear nuts. Lowes didn't have the right diameter of bolt (weird), but I was able to find one and tighten everything up. Put the seat back down, fastened to the floor, and it seems to be good to go!
Yes, the correct bolts have smaller heads so that there is no interference with the operation of the fore and aft movement of the sliders.
If you don't have the correct heads, you can grind down a normal bolt so that it fits.
Since you will probably find the threads these bolts screw into are stripped what I have done is use 1/4 x20 screws with the heads ground off to clear the screw jacks.
