SOLD 53 rebuilt/refurbished vacuum antenna
Started by bariman, May 03, 2022, 04:31:23 PM
bariman
This is a new listing.  I have rebuilt another vacuum antenna that works perfectly.  This one is marked for 1953 but will fit other years as well.  The vacuum cylinder is 24 inches long.  The total length with the mast extended is 73 inches.  The mast is a new stainless steel aftermarket piece in three sections that looks, well, new.  Satisfaction guaranteed.
$350 plus postage
Buchholz001@bellsouth.net
Cadillac Jack 82
Any idea if this will work in a 55?  If so I could use it because my cylinder rings are shot so I have to manually pull it up and down.
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
bariman
This will probably fit a 55.  Can you measure the tube?  Mine is 24 inches which is on the short side so it should fit in your space.  Does yours have a brass top?  This one is brass.  The ones with aluminum tops are different.
Dennis
Bob Hoffmann CLC#96
Guys,
That antenna fits 47 to 53 only.
54 & 55 antennas are the same.
HTH, Bob
Cadillac Jack 82
Dang!  Thank you for the information Bob.
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
