472 rebuild problems running
Started by cadillac73, December 27, 2018, 03:18:14 PM
cadillac73
Hello all. The garage that put my freshly rebuilt engine in just called and said it’s not firing right. They are blaming the carbon fiber plug wires, and are suggesting that I either switch those to steel core or change the ignition to HEI. Someone mentioned Pertronix?  What are your thoughts and what’s the easiest way to get this thing running?
Catherine Smith "Cat"
Pittston, ME  USA
1973 Coupe deVille 472
"Solid Gold"
Cat,
I don't know how many hundreds of MILLIONS of passenger cars that were produced and ran successfully with carbon core, noise suppression spark plug wires. I will go out on a limb and suppose that the shop replaced the wires when they rebuilt the motor. If they did not they should.
Going to steel core wires will generate electrical noise when your radio is operating and will give you no better performance on a stock motor than the carbon core noise suppression wires.
Get them to double-check the firing order, and where No. 1 actually is.
I second that!  Make sure they understand #1 is the front one on the passenger side.  See this way too often with shops that think all GMs are the same and are Chevrolet educated.
Bobby B
Quote from: cadillac73 on December 27, 2018, 03:18:14 PM
Find a shop that knows this engine or an old time mechanic with patience.......
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Cat, this is a damn shame, sounds like you are right back where you were a year or more ago.
Glen
Quote from: "Cadillac Kid"  Greg Surfas 15364 on December 27, 2018, 04:33:54 PM
I have used steel core wires with resistor plugs on my 68 ELDO with no RFI problems.
Glen Houlton CLC #727
CLCMRC benefactor #104
Firing order needs to be checked. It’s a common mistake.
Are they sure enough of their diagnosis that they will pay for all the parts and labor if it doesn't solve the problem?
Was the distributor new or rebuilt?  Make sure they understand how points work too.  If they are blaming the distributor and wires they may not own a dwell meter or know how to use one.
Does it have an AC compressor mounted?  If not one of the rear bracket holes goes into an intake runner, no bolt there would be a big vacuum leak.
rajeevx7
Quote from: The Tassie Devil(le) on December 27, 2018, 04:52:05 PM
I bet that’s right! But, they are saying “just change the wires”? Order a set from advance auto and try. If not (probably not) then the shop can send them back. Doesn’t seem like a high risk option to me to quell their fear of carbon 8)
cadillac73
I don't think it's going to change anything, but I just ordered an electronic distributor for the thing from Summit Racing. The garage is getting impatient and tired of working on it, and I'm so disappointed and sad with this whole year +-long saga. I really wanted the car back today because it's my birthday, but now it won't be until after the new year.   :-\ :( :'(
Pittston, ME  USA
"Solid Gold"
Cat,
I second Bobby's post.  This is a SIMPLE engine and any decent mechanic should not be stymied by the ignition system. If you paid them to rebuild the engine they should not have a financial issue to make it right.
Jeff Rosansky CLC #28373
First of all, happy birthday.
I understand the rebuild frustrations. Mine still idles like crap.
Make sure the shop is accounting for the decreased voltage at the coil with what they are trying to do now and also when they install the new distributor. I put the wrong coil on the 55 and the ballast resistor combined with the internal resistance coil made it so it wouldn't even back out of the garage.
Jeff Rosansky
Which distributor did you get?
Have you seen or heard what the issue is?  Or just going by what they are telling you?
Bobby B
Quote from: cadillac73 on December 28, 2018, 11:38:20 AM
The garage is getting impatient and tired of working on it.....
I knew that from your Post the second I read it. Throwing parts at something doesn't solve anything. I wouldn't have spent a dime on it, or a new distributor for that matter, until they told you EXACTLY what the issue was. Patience is a Virtue, and a lot of people today don't have any.......
        Bobby
1971 Datsun 240Z
1979 H-D FLH
Marty Michaels
Cat check your distributor, make sure it is placed in correct. Just a thought Marty
Marty Michaels
1947 6269
1941 6019s
CLC#26833
