59-60 heater hoses
Started by David Greenburg, February 25, 2013, 01:03:57 AM
David Greenburg
I bypassed my leaky heater core and now that I'm getting ready to fix  it I've lost track of which hose goes to which side of the water pump. Can any of you 59-60 guys help me out?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Jeff Wilk
Dave they should be two different ID's to match the pipe sizes at the core and at the pump.
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
David Greenburg
Thanks, Jeff. I think the hoses on the car are the same size,  but that may be due to previous incompetent work.  If the fittings are different sizes, that should solve the problem, and perhaps a leak.,
David Greenburg
Ed Mobley
Hi,
The larger hose is on the passenger side of the water pump and the smaller hose is on the driver side of the water pump.
Ed
Dan LeBlanc
If they're like 61/62, one should be 5/8" ID and the other 3/4" ID
Dan LeBlanc
David Greenburg
Thanks, all.  Putting on the correct (different sized) hoses makes it pretty clear what goes where.
David Greenburg
60eldo
   Check the 1959 manual, it show pics of the hoses and where they go page 14-28
Jon. Kluczynski
If you need photos let me know.  One of the hoses goes under the manifold from front to back.
Brian
David Greenburg
I looked in the manual but missed that picture.  On my car, as well as my '59, both hoses run under the manifold.  My back has been acting up and I decided I didn't want to fight the battle of pulling the dash in order to get to the heater core, so I took it to my professional guru, an old school mechanic, who was able to remove the heater core without pulling the dash.  Despite the shop manual, apparently you can get to the core after removing the glove box and glove box door.
David Greenburg
