removing pistons
Started by 38operacoupe, January 05, 2016, 09:27:36 AM
38operacoupe
Hi,I am looking for tips/advise on removing connecting rods and pistons on a 322 flathead.What is the best position and removing end cap from the connecting rods.
Thanks Ron
Is this engine seized or just normal disassembly?
38operacoupe
normal disassembly ,its a bit harder than normal I cant really spin the engine in the stand its to heavy!!!
You have to be able to turn the crankshaft over Ron to remove each rod as you cannot get at the cap bolts until the crank is in a particular position for each rod. The pistons then remove up through the bore. You will need a really good 3/16" socket which is also very thin walled to get at the cap bolts because they are well recessed and round off very very easily.
Ron,
What year LaSalle? The early 1937 had screw fasteners which takes a special tool. The later is a 7/16", which again has a special tool.
After that they went to normal fasteners so you could use regular sockets.
Let me know since I have all those special tools.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
What do you have for the bolts John?
Steve,
Will take a few pictures and post.
Got grandkids over this week while daughter and husband are in Mexico. So with a 3 and 5 year old life is now more exciting than I like.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Fred Pennington 25635
Check to see if you have a ridge or lip at the top of the cylinder. It is more likely then not you have one.
You will need to ream out the ridge to remove the pistons without damage.
If you don't have a reamer they are not expensive and some auto parts stores will rent or loan you one.
Good luck
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
