Complete Factory Fuel Port Injection system for 500 inch motor
Started by "Cadillac Kid" Greg Surfas 15364, May 26, 2019, 08:54:54 PM
Complete Fuel Injection system off a running 1976 Eldorado, includes:
1. Power coated (Cadillac Blue of course) Intake
2. 8 Fuel injectors with new set of o-rings
3.Fuel rails with regulator and brackets
4.EGR and solenoid
5. High pressure fuel pump
6. Rebuilt (Cardone) HEI distributor
7.Coolant and air temperature sensors
8. COMPLETE wiring harness
9. ECU10.Throttle body with TPS and Idle air solenoid
11.Front air conditioning compressor bracket
12.All bolts and screws for FI, EGR,fuel rails
Complete System as above $2,250.00 plus the shipping or best offer
Note: Nothing is bolted together and the seals are not installed. Just put together for an overall view.
Cadman-iac
Greg,
Does the same air filter housing for a carb also fit this, or does it require a different one?
CLC# 32373
