!970 radiator Fan blades very unusual to me
Started by Bill Balkie 24172, December 30, 2019, 02:44:44 PM
Bill Balkie 24172
Hello ,
    I would think that the radiator  fan blades  would be perfectly spaced and balanced on any automobile . But  looking at the fan blades on my 70 cadillac they  look very unbalanced and not evenly spaced . Am i missing something here or is there a reason for this . I have included a picture .
    Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
wrefakis
7 blade flex fan replaced clutch fan on 69 much improved cooling
Dan LeBlanc
Even an old 4 blade fan from earlier years looks more like an x than a cross.
Dan LeBlanc
Uneven spacing
Is to reduce the auditory harmonics (noise)
You are fortunate and have the commercial chassis 7 blade fan.  The standard was a 5 blade unevenly spaced as well.  Maybe a heavy duty cooling option utilized the 7 blade fan.  I have switched over to a 7 blade fan on all three of my Cadillacs just for that extra assurance.
The unevenly spaced fan blade is correct.
chrisntam
Quote from: "Cadillac Kid"  Greg Surfas 15364 on December 30, 2019, 03:37:32 PM
Uneven spacing
I always thought the uneven spacing was so you could get to bolts (arm through the void) on the front of the engine.  That's what I've always attributed it to.
Eldorado also got a 7 blade fan.
1970 Deville Convertible
Dallas, Texas
spolij
Gene Beaird
Quote from: chrisntam on December 30, 2019, 09:28:02 PM
Nope.  As Greg noted, it's to reduce NVH (noise, vibration and harmonics).  They don't care if you have to ever remove it after they put it on when the car was built.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
BlackCads
Looking at the picture I noticed that some of the blades are larger than others.
I am guessing this was to offset any imbalance caused by the uneven spacing.
If so, another example of fine Cadillac engineering.
wrench
#9
It’s also why there is an odd number of blades. It marginally reduces noise, but greatly reduces vibration and consequent structural issues with the blades or mounts.
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
