1938 vs 1939-1940 v16 heads
Started by Flathead16, December 17, 2013, 06:43:25 PM
Flathead16
The 1939-1940 heads have freeze plug on the end of the heads. The 1938 doesn't. Are they interchangeable?
    Steve Loechner, Flatheadv16
Brad Ipsen CLC #737
As far as I know they are interchangeable.  Spark plugs are different.  39 and 40 have the 10mm plugs.  38's have the 14mm plugs.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Brad is totally correct,  the plugs are different and the casting vary but the bolt pattern stayed the same throughout making all interchangeable.
Flathead16
Thank you for the help. It's hard to believe all of  the changes that where made on this engine in three years. The pistons,sparkplugs,generator,pulleys,belts and distributor fuel support bracket. Oh yes the oil filter. Did the lube system have any changes?
Thanks Brad,Steve,Boyd and Pete I'm learning from the masters, Steve Loechner
