63/64 Rims on a 65? Rim Color?
Started by Caddyboy65, April 21, 2013, 03:53:28 PM
Caddyboy65
Happy spring everyone!  I'm in the process of replacing my tires on my 65' Sedan DeVille.  When I bought her 13 years ago she had 63'/64' hubcaps on her, and well she still does.  It seems to irritate most enthusiasts who "know" they are not the right ones but I think it gives it some character.  When I came across some 65' Hubcaps at a swap meet I hastilly got home and cleaned them up to put them on the 65'.  Well they didn't fit!  They were not only loose but it seemed like the rims were too big.  Does anyone know if the rims might actually be a 63/64 set?  I already bought rims from a 65/66 but one is black and the others are gray.  I was told that the spare was black but the main rims were gray.  Is this true?  Where could I find info on the actual color of these rims?  I'd like to get them sandblasted and painted with 65' hubcaps for the Grand National.  Also, should I keep the rims as I got it?  OR should I put the 65' rims on it.  Personally pretty torn.  Like the 63/64's but I know some see it as a sin to not have the "exact" hubs on it.  Thanks for your time!
Sincerely,
Daren F. McGettigan
Caddyboy65@aol.com
cadillactim
Daren
1961-64 rims are the same, and 1965-67 rims are the same.  The 61-64 hub caps will not fit on the 65-67 rims and vice versa.  As you have discovered, the 63-64 hub caps are bigger than the 65 hub caps.
Tim Groves
Dan LeBlanc
The closest off the shelf paint colour I've found for doing rims is Ford Tractor Grey. It's readily available, no mixing, ready to go out of the can.
Dan LeBlanc
Gene Beaird
Daren,
I believe that's the way the wheels are on our 68.  Black for the spare, gray for the road wheels.
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
