1952 Power windows stall
Started by FPM, December 18, 2017, 10:53:53 AM
FPM
Hi,
Have a problem with my Series 62 1951 power windows ( Hydroelectric).
They stall at 3/4 of the course: pump stops working, power at pump relay (small wire ) drops at 3 volts.
Then after 20 to 30 seconds it would work again.
Any thoughts?
bullet bob
I wonder if your solenoid is getting tired? I know when I had my motor rebuilt, I just replaced the solenoid at the same time. Has worked great ever since.
Honda Goldwing 1800  "I don't need no stinkin' map, I've still got gas"
V63
I would start with verification of all connections being clean and secure.
Quentin Hall
Definitely sounds like your solenoid. It’s tripping out and takes 20 secs to cool.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
FPM
Well, thanks to your advices, I bypassed the solenoid to test. Didn't work better.
I finally found that the problem comes from the circuit breaker that jumps each time. Can't figure out why.
Caddy Wizard
Here is a stupid thought:  try lubricating the window and window tracks with spray silicone.  If the windows glide easier, you might overcome the HE problems...
Art Gardner
1958 Eldo Seville (2/3 done)
FPM
Hi everyone and thanks for your help!
It helped me to find the problem: circuit breaker was faulty,  contact inside was poor, thus it opened way too earlier than it should. Tested with a fuse of 25 amp ( like it is suposed to be) works fine!
