Oil filter to replace PF-24
Started by "Cadillac Kid" Greg Surfas 15364, April 23, 2022, 02:56:59 PM
I guess I'm late to the dance.  just looked and I am down to about 6 PF-24 oil filters. decided to order some more and found out they have been discontinued. I have seen a lot of discussion regarding a good replacement here, but since I thought the PF-24 was going to be there forever I did not pay any attention.  What are you guys using?
Mike Josephic CLC #3877
Wix 51258/NAPA 1258 is the direct replacement for
the PF24. Wix 51049/NAPA 1049 is a larger full quart
filter that also fits.
I've not tried any of the replacements yet since I still
have PF24's in stock.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Mike Baillargeon #15848
I also ran out of PF-24s....I found these on eBay and purchased the 12 pack lot...Purolator TECH TL25288...
https://www.ebay.com/itm/125137630766?epid=231399936&hash=item1d22c8b62e:g:iscAAOSwgG1iAZGI
Baillargeon
#15848
dadscad
I've been using the Wix 51049 on my 63 for many years. It's a good filter.
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
Scott Nellis
  I recently found that out as well Greg. I got the WIX 51258 as a replacement. The one Mike Josephic mentioned. It says made in Gastonia, North Carolina right on it which makes me feel warm and fuzzy about it. It listed for $16.57 Canadian, but I know the manager at my local auto parts store and bought more than one as well as some Lucas High Zinc Hot Rod and Classic 10W30 so he gave them to me for $9.02 each. Being from Canada that isn't comparing apples to apples, but it is a loose reference point. Hopefully you get a deal on buying a few of them.
1957 Eureka Hearse
1965 Miller-Meteor Hearse
1968 Miller-Meteor Hearse
1968 Fleetwood Brougham
1970 Superior Hearse
Cape Cod Fleetwood
WIX 51258 is what Reid's Automotive told me to use, for ever and ever Amen, after they rebuilt my engine.
"Want to look correct? Spray it Cadillac blue" etc.
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
The PF-24 had a really common thread and gasket size so there are at least a dozen different diameter, length, and micron size filters that will screw on assuming there isn't anything in the way.   Later I will have to look and see if I can find the list I help put together many years ago.   Looks like the 2 most common Wix numbers for Cad motors in Cad cars have been mentioned.
Check out this interchange.
The actual interchange is not as important as the information regarding filtration,, etc. which has been discussed in detail previously. I want to ensure I am going to a good filter.
Wix site is pretty good.   If you have any sort of number to start with you can pull up the specs and see what you are getting.  It doesn't seem to let you auto search similar items so it can take a while but at least if you have some sort of part number to start with that someone said would work you can verify the fit and see what the micron rating is.
https://www.wixfilters.com/Lookup/filterlookup.aspx
dadscad
#10
The Wix 51049 is rated at 21 microns.  The current A/C professional line is rated at 30 microns. I couldn't find a rating for the PF 24.
The Wix 51258 has the same micron rating of 21 and is the cross fit to the PF24.
Enjoy The Ride,
1963 Coupe deVille
Daryl Chesterman
Courtesy of the Rock Auto website, here are the specifications for the AC PF-24 oil filter.
     https://www.rockauto.com/en/moreinfo.php?pk=90097
Daryl Chesterman
Wix or NAPA Gold (made by Wix) --- Wix is what you want.
I can't remember are microns one of the units where the higher the number the smaller the object is?
It's the opposite TJ -- the smaller the micron rating
means that is the limit for what the filter will capture.
In other words, 20 microns is better than 30.
2004 Escalade
