1973 cadillac eldoradeo ,porpation valve on brakes
Started by 34858, December 06, 2023, 12:17:58 PM
34858
Hi how do i check the porpition valve on the brake,
the brake light on the dash come on ,when you  move the wire on the valve the light goes off??
Thanks for  info Kenny
Kenny
Mike Josephic CLC #3877
I have a '73 and I'm familiar with this valve.  If your brakes are working properly, it appears from your description that
this is an electrical issue.  Check the wire connection at the valve to insure it's tight and no corrosion is apparent.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
