68 Deville Convertible steering column
Started by Alluvial, February 14, 2024, 04:12:52 PM
Alluvial
Hi All
My recent purchase 68 Deville convertible has an aftermarket steering column and because of that my footbrake doesn't automatically release when put into drive or reverse, also the neutral safety switch is not working.
Any suggestions for the best way forward to fix this?
Or should I just buy another steering column?
Thanks in advance
Mick
billyoung
You need to purchase another 1968 Steering Column for your car. They are different between the Eldorado and the standard models. I would get a Non Tilt and Telescope one as the turn indicator switch for the T&T column's are not available but replacements for the non ones are about $60 bucks and are easy to get.
Age 69, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
