41 Cadillac 12 volt question
Started by Bob Hoffmann CLC #96, October 30, 2005, 08:56:03 PM
Will the stock 41 Cad ignition switch & starter button work safeley with 12 volts? This is in conjuntion with a complete 12 volt conversion. Thanks, Bob
Ivan Zanatta
The ignition switch should be O.K.
If the solenoid is mounted on the starter, the start button will be O.K.
If its a floor- mounted starter switch (like the old FFFords?) it may get a little hot(double the current if your using a 6volt starter). I have done a 12 volt conversion on a silmilar era Chev and no problems.
Ivan
Doug Houston
Considering just the ignition switch, the current on a 12 volt system is hald that for the 6 volt system.
Now for my questions to you: How are you going to make the dash instruments work properly, even if you use resistors?
What are you gonna do about adapting the radio?
How will you deal with 6 Volt heater motors on your new system?
How will you keep from burning up the clock (if you have the original Jaeger clock)?
Will you use a ballast resistor in the ignition coil primary, and a 12 Volt coil?
How were you misled into this foolish idea in the first place?
Bob Schuman,CLC 254
Dont convert to 12 volts, put the effort into a proper restoration of the 6 volt system, and you will have a reliable system.
Bob Hoffmann CLC#96
