biggest battery that will fit the factory hold down clamp, 76 Eldo
Started by 1776-1976-Eldo, June 16, 2021, 10:26:32 PM
1776-1976-Eldo
The Delco that is in there now is a little short under the hold down clamp. is there a 800CCA battery that folks are using that fits in the factory hold down?
1976 Bicentennial Eldorado #198 Dallas, TX
I found that there was no large battery with the bottom lugs to use with the factory hold-downs on my '72 Eldo, so I would hazard a guess that '76 should be the same.
I got an 800CCA battery, and fabricated my own clamp.
V63
The 72 has that really cool lever release design. The 76 has a top 'strap'. So any battery lower that original should work with appropriate 'lift' under it. That includes most batteries today.
KOKNEYELDO
I have a 75' Eldo with a Duralast 800.
Like, or similar to "Bruce", I bought a small piece of wood, sized it, painted it black and now looks and fits good for the battery clamp.
Present cars:
1975 Cadillac Eldorado convertible
1957 Ford Thunderbird
2007 Jeep Commander Overland
2018 Audi A3
Come On You Blues!
EAM 17806
I have a 76 Coupe Deville with a WalMart "MAXX EVER START" battery and it fits perfectly!  EAM
Ev Marabian
1776-1976-Eldo
Sometimes you cant see the trees through the woods I guess. I did not think of simply lifting the battery to the right height! Thanks all.
