3M DiNoc Wood graining material for dash and window mouldings
Started by Bill Bickle 15098, September 17, 2011, 09:34:59 AM
Bill Bickle 15098
Has anyone had experience using DINOC Woodgraining material on their dash and window mouldings.  Apparently the 1949 used this type of material or it was painted on.  What are your thoughts on using this product?
1927 (7400) and 1940 (5267) LaSalles; 1949 Cadillac 6107
yachtflame
Bill,  Wayne Elsworth here.  I have not used that product or even done any woodgraining but I have a guy in Toronto that has done woond-graining on two of my '30 LaSalles and he is fantastic.  He may know of that product.  If you would like his contact information email me at yachtflame@yahoo.com
Wayne Elsworth
CLC #17075
Jeff Maltby 4194
#2
Bill. Here's a great 1971 mag article on the 48-9 fastback comparision/ how to apply Di Noc.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Paul Tesone
Bill - if you don't have any luck with DiNoc application, check out a company in Idaho called Hydro-Dip . I recently responded to another member's post about woodgraining and told him the same thing . Google Hydro-Dip and take a look at the patterns of woodgrain that are available . If you like what you see ,call and ask for Scott . He recently completed the dash and window surrounds on my 37 convertible . Very helpful and professional . Go to the CLC Restoration Blog and scroll down to my entry on July 20, 2011 titled "1937 6049 series " . You can see photos of his work . Good luck , whatever you decide . Paul Tesone CLC #6876
dan48
The 3M DiNoc being sold today is not the same product used in 48-49 Cad interiors. The current DiNoc is a non-transparent vinyl film that comes in rolls. The most common automotine application is to cover items with a film that looks like carbon fiber. Google DiNoc and you'll find a web site with samples. I think they charged $1 to send me a couple of samples. I thought they looked a little too plastic. There is a nice video on line showing an installation. Another issue is high cost. Local shops had lots of carbon fiber. Anything else, and they had to order an entire roll. I'm still searching for the best way to go on my 48 sedanette.  FYI -  The 48 Cad sedanette is not simulated wood. It is a leather pattern. I contacted Hydro-dip. They do not have a leather pattern. I was the second request for a leather pattern in the last couple of weeks. They promised to search for one. Soooo still looking. I also would like to hear from someone who has used the current DiNoc. Dan48
Dan Lough
Jeff Maltby 4194
#5
Bill.
Click on my name to the left in this post, then click on my email adde.
Having the finest oem 49 woodgrain dash on the planet, I've assisted several others in their attempt to replicate theirs to my pattern. A fellow 49er in NY, had a woodgrainer in florida <jcrentz@comcast.net>, do his after I sent him pictures of my dash.
Jeffo 49er chapter
CLC 1985
marty55cdv
  I have to agree with Paul on this one  Hydro-Dip is the way to go, the look of the finished piece and the durability are great. I had my 41 60S done over two and a half years ago, it looks exactly the same now as the day I put it in
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
marty55cdv
Jeff if I remember correctly it was under 600.00 , back then 1.00 per square inch,   widest point both directions. Might not be the cheapest way, but less than quotes I had for handpainting even with R & Ring the dash myself . Also took less than 3 weeks.   The best thing is was the film is applied it is then sprayed with a automotive clear coat, to maintain it, you use car wax .
Marty Smith
  CLC #22760
56 Fleetwood
