365 head cracking issue
Started by woodillac, September 21, 2017, 10:58:05 AM
woodillac
I've read here and elsewhere that various 365 heads have cracking issues. I've heard about this mainly with respect to '56 heads. Did Cadillac improve head design in the 365 lineage? Or could any 365 head crack, regardless of year?
J. Gomez
Quote from: woodillac on September 21, 2017, 10:58:05 AM
Doug,
The first generation of the ’56 365 had that issue some improvement were made to the later ones for ’56 and the ’57 365.
HTH
J. Gomez
CLC #23082
LV 57 SEDAN DE VILLE
I had cracked heads (both) and my machine shop found severals sets and all of them were also cracked. I solved the problem by getting a set of 1959 390 heads. When using these heads you must also use the rocker shafts and the rocker shaft stands from the 390.
