1964-67 Cadillac Intake Manifold
Started by Kurt Weess, January 26, 2015, 09:26:15 PM
Kurt Weess
Looking for a crack free intake manifold for a 1965 Cadillac with A/C, casting number 1477387.
Kurt Weess
Jeffrey Burland
Hi Kurt,
As mentioned in our text conversation, the 67 will work only if other components and the carb are changed. Stick with the 63-66 as discussed and you'll be fine. Casting number will be the same and this was used on all models so AC or non doesn't matter. They're all drilled and tapped for the compressor. Also, since these don't get that hot, you can usually braze the cracks rather than having to weld them, which is tricky at best. Alumirod works too. This way, since you're going to remove it anyway and the crack is usually on the bottom, only you will know it's been repaired. HTH, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
60eldo
      I have one from a 65 if your interested PM me
Jon. Kluczynski
