Convertible top installation
Started by Ralph Messina CLC 4937, January 02, 2012, 10:58:00 AM
I’ve gotten a few quotes to install a new convertible top on my ’66 and they’re jaw dropping. The prices range from $800 to $1800 just for installation labor. One guy told me the price includes new “cables and wires”. What wires? Is he confusing it with the scissor type? I haven’t had a convertible top done in 15 years, so my past  experience won’t be relevant. I’d appreciate it if someone would share their more recent pricing experience. I believe in a fair day’s wage but my intuition is yelling “Rip off”.
Ralph
2018 GMC Yukon
Alan Harris CLC#1513
Your car (and most others) has a wire on either side that goes through a pocket on each side of the top and holds down the sides so that they are snug with the sides of the top frame.
I have done two of these tops myself when I was much younger. I can attest that for a novice, it is a very hard job, but I agree that the prices you were quoted seem outrageous.
About 25 years ago, I remember that it was hard to find an upholsterer to install a top. They all told me that there was more money to be made doing the fake tops that were popular then. I guess that as it gets harder to find a person willing to do the job, the job gets more and more expensive.
1800 seems a little high for labor.   I had a top done last fall and I think the labor was $650.  I had got a few quotes, I think the highest was $1200.  I decided to go with the low one and got a terrible job.  The actual top was not bad but the mechanism was improperly adjusted some time in the past and I told them that before the job that it needed work.  2 return trips and it now sort of works but looks worse than before.
m schantz
A complete new top, parts and labor, here in Pasadena CA. goes for about $1,200 to $1,500 depending upon year, model and the gauge of Vicotec top one purchases. That' should be accurate for the ret of the country as well. Add $200 for a glass rear window. Michael
Guys,
Thanks for your replies.....Very helpful.
Ralph
2018 GMC Yukon
62droptop
like others suggest, definately not somewhere to cheap out as the results could haunt you for years
and cheaper to spend a lot more the first time than to spend a lesser amount and have to spend the big$$ again on top of that
ask around the local car guys and for references if you can
All I can add is that you are lucky in USA where you have people that can do these things full time.
